hey i got question about shelving. Does using a low shelf (fabfilter proq2) with say a slope of 18db cause any kinna bump in the freq range? need to know if does that like hi pass filter
thnks
I can't answer as someone who has a Fabfilter Prog2. But I can tell you there have been many times I've cut some low end on and and my track has increased in the mids and sometimes a bit in the lower treble range. What I did one time to see the difference was to take a screen shot of the before and the after and noted the changes in frequency.
I don't know Fabfilter, but recently I was mastering a reggae album I had been working on and after the mastering compression went on the bass was bit strong. I fixed it by a multi-band compressor at the end of the chain, and on the multi-band lowering the output of the low end and some of the low mid. You can adjust the frequencies of where the multi-band splits. This worked better then using an eq.
thnks
I just tested a low shelf 18db slope on one of my projects and did not see any bump. What frequency are you pulling up the roll-off to?
I tested on a bass guitar track with roll-off at 70 Hz, and saw no bump in the analyzer. Also did not hear anything change. Other than the needed low end of the bass guitar was gone.
