Low volume for Fostex MR8 11
Nazareth94
Ok, please show me the way--
I've finally started working with my MR11 8track and all is well EXCEPT I can't get strong volume readings. Though the instructions warn of setting the trim too high and clipping the high end--I can barely get the volume setting to an expectable range without resorting to the highest levels 8-10.
So far I've been using only MXL mics with the phantom power (spoken word stuff) --but even the internal mic has to be turned up way too high for the right results.
Is it all about pre-amp punch?
Tim
This is a known problem. (I don't know the answer) Go To
homerecording.com/bbs/sitemap/f-16-p-7.html
This is the archive for Fostex - bit of a trawl but you may find the solution there.
Good Luck.
