K
kEVINk
I have some questions about low-mid absorption that I’m hoping someone can help me with.
Specifically, on the John Sayers site, he refers to hanging panels (Dacron over MDF), usually shown in a ceiling cavity (for example, of varying lengths in the back of a control room). Please note that I am not referring to what some people refer to a bass traps, which, as I understand it, are triangular shaped wedges that are applied to the corners on the finish side of a room. If I am using the wrong terms, please correct me.
So, while I think I understand the hanging panels in concept, in execution I’m still a bit in the dark. My questions are:
1. In one drawing on the John Sayers site, these low-mid panels are shown under a recessed studio monitor with a “port” at toe level, an opening for offending frequencies to go in and die. By this I assume the wall around the panels is something solid; say two layers of GWB of different thicknesses.
2. In another drawing, cut through the control room, shows the back of a control room with a ceiling sloping down toward the back of the room, with the ceiling space above the sloping ceiling filled with low-mid panels of different lengths, alternating in directions. At the back studio wall, these panels extend down to the floor in the cavity. The site gives a recommended width of panel (I think it was around 18"). This section does not show ports.
3. This is where I get confused. Are these panels in a “sealed” cavity between rooms? Or do they need ports for the sound to get in? What if the wall separating them from the studio was covered with some sort of “acoustically transparent” material? (For example, we have access to 100 yards of Marshall cabinet grill fabric.....don’t ask).
4. Is there a minimum size for these to be effective? For example, we are working in a basement with exposed ceiling joists. The depth of the joist is 8". My thought was to fill this space with very shallow panels in alternating directions, then to apply a fabric cover to the ends of the joists, covering the panels. Closer to the walls, the panels get longer. Is a panel of 8" worth it?
5. Is there a way to compute the size or area of panels needed; or, as I suspect, do you just put in as much as you possibly can?
I know I’ve asked a lot; thanks to anyone who is able to help
k
k
