Oh, I think I see. The 410 cab is not a bass cab, so you want to protect it from the low end. That makes sense, though it really has nothing to do with the head at all; bass heads are full range (except for a few that have biamp capability built in). To protect that cab you'd need a Xover even with a (normal, non biamped) bass head.
All you really need, though, is a blocking cap for the 410; there's no real down side to sending the full range signal to the 115. You could mount a blocking cap in series with the speakers inside the 410 and not carry anything extra.
OTOH, if the 410 is a bass cab, you don't need either a Xover or blocking cap; just plug and play.
IIRC, the formula for the blocking cap is:
C = 1/2(pi)Rf = 1/2(pi)(8)(150) = ~133uF, assuming 8 ohms for the 410 cab.
Get as close to a 133uF bipolar electrolytic cap as you can find with plenty of voltage tolerance, or you could use 3 47uF's in parallel to get 141uF (which is plenty close enough) - I believe that 47uF is a standard size. I've done this to block low frequencies from stage monitors and it works just fine.
