B
BigEZ
The Devil Has Blue Eyes
I'm using a c414 xlii and an la-610se. Should I low cut on the mic or the pre or both?
Thanks,
Thanks,
What if I want to take the room out a bit? I've heard cutting at 70 on the 610 might be a good idea?
That's like asking whether your windscreen wipers should be on fast or slow wipe. How in Jupiter's dimension can anyone know ?Should I low cut on the mic or the pre or both?
Don’t know how far you’re into live sound (just part timer here), but I’d disagree. Voc pops’/thumps rumble’ alone don’t follow that ‘60Hz cutoff.... on stage outside I don`t use low cut on vocals the vois can never go lower then 60hz Or your name is Lemmy
