Looking For Feedback Destroyers
  • Thread starter Thread starter Treeline
Treeline
Treeline
Just checking to see if anyone had any experience with feedback locators / eqs. I'm looking at a Behringer DSP1100P, and automatic sensing / EQ on the fly filter kind of thing. Any war tales?
Come to think of it, maybe I should be in a different forum. Oh, well.
I have used the Behringer model. It's kind of good you put it in here because the thing doesnt work with guitars. If you use automatic setting and mic your guitars, it will cancel them out because any wanted feedback that is really sustain is seen as bad feedback. It will swipe off the guitar frequency really quick. Other than guitars, it has seemed to work rather ok.
H2H
I used the feedback killer in the Behringer Ultracurve once in a live situation and it did something weird, when the first freq started to ring it caught it after a couple seconds like it was supposed to and applied a 3 or 4 db cut, cool, but when I went up with the gain again and the same frequency started ringing it didn't cut it any farther, just left the same 3 db cut. I ended up not using it and just ringing out the monitors by ear.
The problem with the feedback exterminators is that when you use them with good monitors that have a pretty flat response you have to crank the gain pretty high to get all 6 (is it 6 or 4 ?I cant remember) filters locked on their frequencies this can sometimes cause you to blow drivers. If you dont lock the frequencies it will hunt and kill random things like keyboard pads etc.
