Looking For A Stereo Fader Pedal
  • Thread starter Thread starter Dani Pace
D
Dani Pace
I frequently use 2 amps, one I set clean and the other I set on the gain chanel. I'm looking for a pedal which when depressed will allow me to fade from one amp to the other. I want to be able to blend the sounds from both amps, sometimes more of one or the other, depending on the song. Anyone know of a pedal which does this? I have an A-B splitter but it just switches from one amp to the other or both. I want this pedal mainly for live use so I can fade and blend the sound from both amps without having to turn knobs. I'd really like to find something with a rocker pedal (kind of like a wah pedal) which would work like an A-B stereo balance/fader. I'm sure other players have wanted or needed something to do this, so surely someone makes them, I'm just not having any luck finding one.
Pretty sure you can route a stereo Volume pedal to do this.
Morley used to make a pedal (like wah) that would allow you to pan between to amps, that should do. I don't know if they still make them. Good luck.
Boss has stereo volume pedals that does what you're looking for.
Dani Pace said:
Thanks, that looks a lot like what I'm hunting. Maybe I can find one now that I have a better idea of what to ask for.
I have one of those Ernie Ball pedals like the one pictured and I have used it at least 15 years without a single problem. The lever at the top will reverse the volume/panning function to the 2 seperate amps-and it is built like a tank and the volume pot is easily replaced-though in all those years I have never had to. My older pedal also has a pot to preset the minimum volume so it can function as a Lead/rhythm pedal-great for taking a solo and dropping back to rhythm mode. Try ebay, I got mine in a Mom & Pop music store for a bargain price-I will NEVER let go of it either-Its perfect!
I just checked my pedal and there is no model number anywhere-its very close to the one in the link below though.........
http://www.sweetwater.com/store/detail/EB6165/
