Looking for a good book
  • Thread starter Thread starter gusfinley
G
gusfinley
I am very intersted in learning about Vaccum Tubes and how to conjur up my own amps and modify amps which use them. What exactly do i need to Learn to be able to do this?
I have heard of RCA recieving tube manuals - are these going to help me learn about how to use tubes in circuits?
Thanks for any help............
Fortunately, you don't need to be an engineer to repair, service, mod, or even design a basic amplifier. Though as time goes on, you will find yourself getting deeper and deeper in a quest for understanding. That's what happened to me, anyway.
RCA receiving manual- basic tube function and design. Required reading for tube heads.
Radio Shack or other book on basic electronics- info on basic components and their functions, and basic electronics theory.
Radio Shack or other book on soldering. Good soldering is pretty much the most important manual skill to have. Understanding why & how soldering works helps you to realize how critical good joints are.
Some basic books on guitar amp repair and servicing. Learning how to service amps is a great way to understand them.
Here is a link to Magic parts catalog. Click on books. I recommend Gerald Weber's book for good background and mods, and Dan Torres, Dave Funk, and Tom Mitchell's books as a starting point. The Brosnac book is good, especially for building, and the Torres book has step-by-step walkthroughs of a small amp project. It took me reading a few different books to get the basics. You find the guy you can understand. Be warned- some are not cheap. You may find a better source somewhere else besides Magic. Get an old Fender tube Champ- pretty much as simple as it gets. Power supply, preamp, output section. Take it apart, look at it, understand it. All amps are basically derived from Fenders, on some level.
READ AND FOLLOW ALL SAFETY GUIDELINES. Tube amps, even small ones, can carry lethal voltages.
AX84's P1 theory document. The Carl B/ Matthias M load lines document, also at AX84.
aikenamps.com technical section, in particular the common cathode design and LTPI design articles.
Check your local library for tube books, you might find some there. My library had Rozenblitt's Beginner's Guide to Tube Design, which is a decent place to start.
If you're buying books, Kevin O'Connor's TUT1 and TUT3 are good places to start. They're at londonpower.com and others.
I don't have the RCA tube manual yet, but I've been thinking about finding a copy to get better at the theory stuff.
Start with a simple amp like the Champ or the AX84 P1 or P1 Extreme, which other folks have built before. Or even start with a one transistor pedal like the Rangemaster or NPN booster over at diystompboxes.com.
Thanks for the Aiken link, chill. Good site. And the other info. I was happy to find I had most of the books he lists as important, and mentioned the right ones to Gus. (I always feel insecure recommending things like that to people. Somehow someone I don't know mentioning them on the web makes me feel better :rolleyes:)
