gstoelen
Hi all,
I'm quite new to integrating hardware synths into Logic Pro, and I ran into an issue. A few days ago I purchased a Behringer UMC1820 with an extension, the ADA8200. I think I cabled them correctly - the ADA8200 is set to slave, the ADAT/SPIF button on the front of the 1820 is set to ADAT, and I connected two optical cables: one going from ADA8200 OUT to the 1820 IN, and vice versa. When I hook up a synth to port 1 of the ADA8200, I get a signal on the LED. So that seems fine as well.
The 1820 is seen by Logic Pro without issues, so when I create a new track, I can pick any of the 1820's inputs (1-8) and sound comes thru the speakers just fine.
However, for some reason the ADA8200 doesn't seem to send any audio to the speakers - after doing some research, it seems you can't use the ADA8200 without a DAW. Or at least that's how I understood it.
In Logic Pro, the ADAT inputs aren't labelled as such, and I find it confusing. So inputs 1-8 come from the 1820 and they all work fine without issues. I can play on the keyboard and I can at least hear what I'm doing. But when I create a new audio track and I select input 11, then I can record the synth that's plugged into port 1 of the ADA8200, but I don't get real-time audio (meaning when I play the keyboard, I hear nothing).. is it supposed to work this way? I hope my explanation makes sense; English is not my primary language.
Any help would be highly appreciated!
