Chris Tondreau
Member
Hey there;
To some degree, I'm sure this topic has been covered to death, and I have read a great deal on it already. The dillemma that I'm experiencing, though, goes a bit beyond what is typically covered.
I know that many guitarists/producers, etc. will use a sound that is not what they would typically use in a live situation for when they are recording - for a variety of reasons. I've been playing for 20 years, and am still tweaking my live sound, but am getting closer to what I want all the time.
I have a BC Rich Bich guitar (main) and a late '70's El Degas (from when they used to make good guitars) as my "string buster." I run into an ART ECC processor (which I think is pretty good.... if any of you are familiar with Pete Lesperance from Harem Scarem - he's awesome, and I believe he uses/d one, unless there is another that looks a whole lot like it). From there, I use a Yorkville 150 watt head and 2x12 Yorkville cabinet. The amp is used primarily for power on the clean channel, as I use the ART for distortion too.
One of my key problems is with definition in my sound. My notes, chords, etc. seem to lack clear attack. This is more of a problem recording than live. What could this be due to?
I also find that when I'm recording, I have to take a lot of the mids out (pretty much gut the frequencies around 5K, or turn the mids way down on the amp) to get results that are approximating acceptable. I don't have this problem live.
I guess I should note that I have been recording with a Sure SM58 pointed on a slight angle directly at the outside of the cone of the speaker, and a TOA (which I believe is a foreign knock-off of an SM58, as it looks and sounds remarkably similar) hanging down in front of the other speaker so that it is perpendicular to it and actually leaning against the grille. The mics are plugged into a Behringer MX802 Eurorack mixer, and then into a Delta 44 soundcard into Cubase VST.
I know that the sound you hear in the room is not necessarily the sound that the mic picks up when it is right in front of the speaker, but is this gutting of the midrange frequencies typical of most recording situations? It seems to me to be counter-intuitive, in that nothing has this sort of an EQ curve naturally. At the same time, though, it kind of makes sense in that this same mid range is typically where the vocals will lie.
Part of the solution may well lie in my preamp when recording. I have achieved somewhat better results with my Peavey TMP1 mic pre.
You can listen to some samples at www.soundclick.com/christondreau and the first two songs are the worst for guitar tone. The third one is acoustic, which I have been quite happy with, and the fourth is electric, but doesn't illustrate my problems as much as the first two.
Any advice would be appreciated!!
Thanks!
Chris
For the acoustic song, I used a Rode NT1, pointing at the twelfth fret and angled slightly towards the body of the guitar about a foot or so away from it, and then into the Peavey TMP1, and the Sure SM58 pointing towards the guitar, about a two feet away from the nut, going into the Behringer mixer. It worked pretty well. I played the solos twice, and panned each take left and right. I was quite happy with how synced they were!
Thanks!
Chris
