R
ronfya
Hello all,
I'm entending to record a live show on 16 tracks with 2 MOTU896HD.
The console that will be used for the live is an Allen & Heath GL2200.
I was wondering if someone has ever tried to record a live show with MOTU896HD because my question is the following ...
Considering that :
-Direct outputs of the console are postEQ only, so I don't wan't to use them to feed the MOTU.
-Inserts of the console might be used so I prefer to keep this as the last solution.
-I don't have any splitters to split the signal PRE-Everything and then feed the MOTU and the console after the split
--> the only option I see is to use the MOTU 8 outputs and then feed the console strips... but as there will be 2 preamps in the audio path (the MOTU preamp and the console preamp), I'm wondering if there wouldn't be a problem of noise and a problem of handling the live mix ...
What do you think guys ?
Considering that :
