Seafroggys
So for my band's next gig, I thought it would be a cool idea if I brought my recording rig in and recorded ourselves. Its a pretty small venue, we've played there a week ago and all we do is mic the vocals and snare drum and bass drum through the PA and let everything else just breathe.
I'm not sure what the outs are on the PA mixer, I'd have to take a look. I have a Firestudio, so my options are fairly open. These are what I have in mind:
1: My first thought was to place two LDCs (my Rode NT2-As) in front of the band, and use those to capture the main sound. Run a stereo out from the PA into the firestudio, and add that as needed to add some cleanliness to the vocals and snare/bass. I'd probably run the Rode mics as cardoid instead of omni to prevent the sound from being too muddy.
2: Same setup as above, but run the mics through the Firestudio first and then out into the PA. Again, it depends on the mixer, and if the computer fails for some reason, the PA fails as well, which is what we don't want. This allows for further seperation.
3: Add a bit more. The bass amp has a lineout. I can put that into the Firestudio as well, I can run a pretty high high-pass filter on the DI, so that the clarity and tightness comes through without making the fundamentals and boominess overbearing.
4: Throw up a mic on the guitar amp and only run it into the Firestudio, in addition to the line-out from the bass. This will make the guitar and bass more defined and provides more seperation, but also makes the whole ordeal more complicated. At this point I would run my LDCs as omnis to get the whole room sound, since I can rely on the close-ups for the definition. In this case, the drums lose focus, since only the snare and bass drum are micced. I don't have any extra condensors to mic the drums, so I'd have to through one of my RODEs on the drums and leave one for a room mic.
For a first time live recording, considering its just a bar, I'm not going to go #4, but 1-3 are definite possibilities. What do you guys think?
