PDP
There once was a note
I noticed something about my mixes lately, which is that the sustain of the bass (in particular) changes on different playback systems, sometimes quite noticably. In some cases it even sounds as if it drops out.
I use very short (in fact the shortest) release settings on my Mastering limiter because it sounds bigger and less squashed, but I wonder if its so short its not carrying out the mix enough. In general, I tend to use compression in general (while recording) say at a 6:1 and knock off 2-3db, rather than say 3:1 and knock off 5-6db, for the same reason, its a more open sound to me.
I just started playing around with the transient designer (envelope shaper) in Cubase 7. Very powerful tool. You can get a snare drum so tight it sounds like it will pop the speaker, or so loose it sounds like someone hitting a garbage can.
So, any suggestions on the release of mixing overall? and does anyone use envelope shapers much on any instruments other than drums.
Pete
Pete
