Lexicon Effects Processor I/O Level Set...Woooo!
  • Thread starter Thread starter mark4man
mark4man
mark4man
MoonMix Studios
OK...
This makes no sense to me.
I'm bustin' the ceiling with my Effects Processor's minimal settings
I'm running the Lexicon MPX-500 w/ an Echo Audio LAYLA 24/96 PC AI. I'm looping my dry, prerecorded signal out of the Layla's 3/4 Outs...in & out of the Lexicon; & back into the Laya's 3/4 Ins (all balanced.)
I have the Layla's Nominal Output (for 3/4) set to +4dB.
I have the Lexicon's Input Trim fully counterclockwise.
I have the Layla's Nominal Input (for 3/4) set to +4dB.
These settings cause audible clipping in the recorded input signal within my DAW (SONAR XL) (& also visible within the meters both in SONAR & the Layla's Console.)
The Lexicon's User Guide states that the device's output level must be set at 0dB (Unity Gain, fully counterclockwise) , for an input device of +4dB.
What's the deal?
Of course, I can rectify the clipping problem by attenuating either the Layla's Ins or Outs; & then rolling the Lexicon's Input Trim up to just below peak...but then I'm not taking full advantage of the full dynamic range of the system, right?
The Lexicon does have a -12dB Output Level setting, but the User Guide states that is to be used with -10dB input device.
Any ideas?
Thanks,
mark4man
If the signal originating from the DAW is higher than about -15dBFS, then you can definitely be clipping the inputs on the Lexicon.
An analog signal at about 0VU at the +4dBu gain structure will read about -15dBFS.... so in sending a digital signal back that is far higher than -15dBFS, you are sending a signal several times stronger than the inputs of the Lexicon at the +4 can handle cleanly.....
Bruce,
Thanks.
If true...why do you suppose it is recommended to be set up in this way?
OR, more importantly: the fix I mentioned (attenuation of Audio Interface In or Out) (at the beginning or end of the effects loop)...which one would be better; & why?
[But then...what about not taking advantage of the full dynamic range of the system (which is sort of a mute point if I'm clipping...), but then again, by inputting a -10dB signal back into the DAW to be recorded...aren't I pushing up the noise floor when I push that -10dB signal back up near 0dBFS for recording?]
Thanks,
mark4man
BTW - How's everything at BlueBear?
Things are good - busy!
What you're encountering is exactly what happens when you interface analog and digital signals that have different scales of signal strength....
I describe the issue in greater detail in this article --> Meters, Signal Levels, and Headroom
Bruce,
Thanks.
(BTW - Great article!)
As you mentioned earlier, if the Effects Processor's inputs are the first stage to be problematic...then that's where I'll attenuate (at The Layla's Outs.)
Thanks again,
mark4man
