dobro
Hi. I don't come in here much, but I've got a recording issue that's really bothering me, and useful input would be...well, useful.
I learned that I should track as hot as possible, so I've used either compression or limiting when tracking to prevent clipping. But recently Lt Bob talked about how he doesn't compress his stuff at all, and Sluice talked about how he recorded at much lower levels than a lot of people here and yet when he brought the gain up later on, it wasn't too noisy. So last night I tracked some vocals without any compression or limiting, and it sounded good and there was less sibilance than usual. But those levels! Really hard to prevent clipping, cuz I don't have good enough singing control. So, should I just turn the level way down, and have the peaks hitting at -12 instead of -3?
I was in a pro studio last week watching some voiceovers, and the engineer decided to track it at 16-bit and the meters were hitting about -12 dB. I asked him why so low, and he said it wasn't low, because he wasn't going to have to boost the level much. But he highlighted a quiet section of the track and then *did* boost it 10 dB to show me the sound, and there was loads of hiss. Ouch. Now, was that cuz he was tracking at 16-bit? Does tracking at 24-bit allow you to record at lower levels?
I want the answer to be yes.
