LeeRosario
I was thinking about the whole "analog tape emulation vs the actual thing" debate and I started doing some experimentation of my own. I took a very scientific approach to the whole thing and want to present my findings with the community. I'm notoriously OCD with this type of stuff, so you can skip to the conclusion if you don't want to read the details.
The process is a pain in the ass since I have no way to sync my VHS to any of my gear. However, I did come up with a way to re-sync my tracks later on in the process.
I'm hoping the professional mastering engineers can help me refine my testing approach and/or technique. I might have missed something or simply lack a better way to do this. I figure this is somewhat incomplete. I can use some other brains on this...
I call it "Hi-Fi/Lo Fi"
Live Drums Sample:
http://soundclick.com/share?songid=8003433
(First half is unprocessed and second half is processed through the VHS deck. Separated at the blip sound)
Tracked at my place using an 002 rack @ 32-bit, 96khz stereo
File: MP3
Problem and Question: I hate the harshness and "coldness" of projects I must record at home. I'm not satisfied with any tape simulation software I've found out there, so how can I get actual tape processing at home?
Hypothesis: By running my tracks through VHS tape at home, then bouncing it back to my computer, I can get a true to life "analog tape" sound that is much more pleasant to the human ear.
So if research tells me that VHS is about the same as CD quality, why not try it?
Variables that I must take into account:
Quality of the source recordings
The VHS tape Medium
VHS Tape Quality
VHS Deck Quality (specificly the write head quality)
A/D/A Converter Quality of the digital multitrack (in this case the 002 rack)
Jitter
possible issues using an unbalanced signal transfer method (RCA cables)
Bit Depth and sample rate
Sync issues and track realignment
Phase issues (if passing stereo signals as opposed to mono)
Summary:Research on the VHS Tape Medium
Like 2inch tape used in professional studios, the VHS medium is inherently magnetic in nature and uses the same basic principles of operation. The magnetic tape medium is widely regarded as "extremely pleasent to the human ear" by order of harmonics, wow and flutter.
The quality yielded by VHS tape is comparable to CD quality at the very least. It can hold the full range of audible frequencies with a relatively low signal-to-noise ratio, which is dependant on the quality of the tape record head, circuitry and A/D/A quality during the transfer process.
Obviously, a VHS tape deck record head was never intended for professional production applications and is not comparable to a $100k pro quality tape machine that boasts highly expensive record heads. Nor is a VHS tape compared to a 2inch reel that runs into a 3 digit price tag per reel.
Inevitably, compromises must be made.
Tools used:
-Signal generator to test for phase, frequency response, dynamic range, tape compression (if any) and any other changes.
-Modified Digidesign 002 with RCA In/Out.
-Simple DAW software with the ability to test for phase, freq response, dynamic range and any other variables.
-Sony Hi-Fi Stereo VHS recorder with 19 Micron head
-Maxell T-160 Standard Grade VHS Tape
-XDR Pres on Mackie VLX Pro board
-Beyer Dynamic DT990 Pro reference headphones
-Tannoy Reveal (Passive)
-Roger Nichols inspector Metering
-Bob Katz Mastering Audio Book (reference)
-My ears
Testing Process:
Step1: Scientific Testing
Before attempting to run my mixes through VHS tape, I wanted to find out what the deck was scientifically doing to my signal. I ran a few simple tests through my RCA sends and returns.
First, I sent out a stereo @ 32-bit, 96khz pink noise signal at about -3 RMS (my target quality with headroom), recorded it to tape and recorded it back into my DAW. I obviously couldn't do this in real time, since there is no way to sync my tape deck with the multitrack. So certain tests where impossible to conduct.
I was happy to find that the frequency response had not changed except for a high roll off at around 36khz. I assume this has to do with the 002 A/D/A conversion process.
A problem showed up when I tested for stereo balance. The processed signal gave me unequal RMS for Left and Right. Left read around -2.5 while right read around -3.5. That's an entire DB of difference. I can't understand why.
Dynamic Range seemed relatively equal with little or no tape noise in the signal.
A 1khz tone confirmed the L/R balance offset. Scientifically, this is no good for stereo mixes, because I didn't get an exact return on L/R balance. It might throw off the entire mix. However, I figured I'd let a subjective test of an actual stereo mix give me a final verdict.
Step2: Practical Testing
After the scientific stuff was done, I took an old unmastered stereo mix I had done and passed it through the tape deck.
I was happy to find that most of what I predicted occurred. I got a softer, rounder, fatter signal with a little grit added. Some tape saturation was also present.
However, the stereo image had degraded substantially: more notably in the center channels. The middle of the stereo image became somewhat cloudy and cluttered with a subjective loss in clarity of around 30%.
100% being an exact copy in transparency and 0% being a completely undefinable copy. Completely mushed sound.
Sending out the signal at a lower RMS (no greater than about -15 RMS) yielded slightly cleaner results, but still not transparent enough for me to consider it as "pre mastering" tape processing. The tone was great, but the image was suffering to much.
Several different premastered mixes confirmed the findings. Whether it was due to the unbalanced connections, the circuitry involved, actual tape compression/saturation or the A/D/A conversion, I don't know.
I wish I had a ultra high quality A/D/A converter to really confirm this.
I then decided to try processing individual tracks through the tape deck, leaving the stereo summing up to a more capable DAW and/or analog desk. Obviously, I don't have an SSL 9000J on hand, so I did the summing "inside the box."
The main issue here was syncing up my tracks. Without a way to sync the tape deck to any studio gear, I developed a very simple method of re-syncing my tracks.
I used a 1khz square wave signal as a marker at the beginning of my tracks. I recorded the processed tracks back into my DAW with the square wave marker. Then by simply cutting at the zero crossing point of the marker (using any simple tab to transient function), I was able to cut and slide my tracks back into sync.
The results yielded very fat, soft, rounded and saturated tracks. I also still have the power to mix and additionally process the individual tracks to my tastes. The harshness was gone and I still had total control over my mix.
Conclusion:
In conclusion, by conducting simple tests with a signal generator and a few standard measuring tools, as well as subjective listening tests to actual mixes, I was able to determine that the VHS tape medium does in fact yield a smoother, warmer, fatter and thicker audio track that it's unprocessed counterpart does not possess. It also yields a slight amount of "musical grit" that adds to a sense of excitement. These of course are all highly debatable and subjective terms.
I felt smoother highs and rounder, thicker lows. I noticed a definable mid range that's not overbearin and that the overall tonal "feel" is more pleasant, even in a digital medium. I observed a more natural stereo feel when leaving the summing outside the VHS tape deck.
The test assumes that you have a capable VHS deck with RCA ins and outs, as well as some form of DAW with RCA ins and outs as well. Theoretically, better A/D/A converters and generally better gear, should improve this process.
By processing premastered and mastered stereo mixes through the VHS tape deck, I did observe a significant loss of transparency that yields a 30% cloudier stereo image. The mid channels suffered most while the side channel material seem least affected. I also determined a Left/Right offset of about 1db that may be unacceptable by professional standards. In some forms of music, particularly grungier music, this may be desired. However, it comes with the risk of unpredictability.
I was unable to determine if it was simply because of the VHS Deck, VHS tape or DAW circuitry itself.
I found better results in processing mono tracks by means of using only the left side (the hotter side) of the VHS deck and DAW, using a simple "tab to transient" signal marker method to realign the tracks. This yielded the benefits of analog tape while still giving me complete control over my mix. This also leaves stereo processing to the mixing platform itself and not to the VHS deck.
So while VHS tape can never be compared to 2inch reel and a VHS deck compared to a professional tape machine, the benefits are clearly present with a bit of work involved.
Thanks for your time, I'm open to advise and help!
My Report on Analog Tape done at Home using cheap materials
Live Drums Sample:
File: MP3
The VHS tape Medium
VHS Tape Quality
Jitter
Tools used:
-My ears
Testing Process:
Conclusion:
