dobro
Full Reverb does this "Left-Right Location" thing. But does it work only on a stereo track?
Have you ever applied a reverb to a stereo mix and noticed that all of a sudden the file is in mono? That little "combine source left and right" box is INDEED a scary default setting for the unwary. I think the purpose of it is to save on CPU usage when you have a left and right channel that are exactly the same (but we're all too smart to record mono in stereo, right?).ozpeter said:I think it's actually only intended for mono files. Put it this way, your source will be reduced to mono unless BOTH "combine source left and right" and "include direct" are NOT ticked - which is something of a snare for the unwary.
chrisharris said:Have you ever applied a reverb to a stereo mix and noticed that all of a sudden the file is in mono? That little "combine source left and right" box is INDEED a scary default setting for the unwary. I think the purpose of it is to save on CPU usage when you have a left and right channel that are exactly the same (but we're all too smart to record mono in stereo, right?).
