RecordingMaster
A Sarcastic Statement
I have some left over OC705 scraps (6 lb/cubic foot fiberglass insulation), from making some tri-corner traps a while ago, since I had to really knife them up to get them into a triangle shape and bevel the inside edge so it fits neatly in the upper corner of wall/ceiling...Some pieces are maybe a 2' X 0.5', some are 5 inches by 5 inches, some are...you get the point - they're all random (so I can't make these into a panel style trap). I have about 3/4 of a garbage bag filled with these scraps.
As of now, they are sitting in my garage, likely absorbing dampness and getting smellier (that stuff already smells pretty wrank). I figure, you can never have too much low-end absorption, and I already have enough broadband absorption in my control room. At first, I thought "Well I could literally just put this garbage bag full of scraps straight into the control room, in one of the floor/wall corners, preferable behind my side rack (which is next to my desk), on the floor so you can't see it." I was using the theory that if you have a reflective surface on the outside of your bass trap, it will absorb more bass and less/no high frequencies. Then I remembered that, one side needs to be uncovered (the side facing wall). So I'm not sure how I'd do this...I was thinking of maybe putting it inside a fabric bag (duffle bag?) that is acoustically breathable, and line the one side facing out with some butcher paper (waxy/glossy side facing out), and stand the bag on it's end, so it's like a cylindrical shape standing tall. Lean the top end against the wall, and leave some space between the bottom end and the wall so there's is some better absorption.
Any other ideas though? Is there some sort of floor bass trap you guys/gals think I could make that would be a little less ghetto or perform a little better than my hobo duffle bag idea?
I know this likely won't make a huge difference in my low end absorption, having it on the floor behind a reflective rack unit and all, but I figured it would be somewhat better adding this to what's already treated in the room.
Any suggestions are welcome.
Thanks!
Thanks!
