Bloodsoaked
Death Metal Freak
Check out my latest Death Metal Mix: http://bloodsoaked.metalhordes.com
Leave your comments....
Peter
Peter
antispatula said:doesn't work
xstatic said:All in all not too bad. The vocal seems a little too "detached" for me.
I did however take a look at your website. There is a lot of information on there I would consider changing.....
"Acoustic guitars - Whenever possible, record acoustic instruments with a line in directly to the board or soundcard, you can run them through a compressor or whatever else first, but just don't mic them. They are not loud enough to create a strong enough signal to filter out hiss and other noise around them. If your acoustic does not have a pickup, go buy one to put in it.
"you NEED a good speaker system for you pc WITH a subwoofer."
"If the band wants to smoke in the musicians room, then fine, it's their stuff not yours"
"SM58 - Guitars - these are about the same as a 57 only omnidirectional."
"I use the compressor within my Boss ME50 Guitar Processor, it works awesome.
"Ever wonder how the pro studio's record a kit without the cymbals bleeding through the snare mic or any other mic on the kit? Well I found the answer after a long time searching. Not just any gate system, for instance, the old 2 knob peavey gates will not do what we need, they are more suited for live performance. What I found is this; The Behringer multigate pro xr4400. This little miracle lets you filter out frequencies, so if you have cymbal bleed, simply use the controls to sweep it out. Notice the Parametric Filter."
xstatic said:Those are all quotes i pulled off of the Demon Digital Website. Some of that "information" seems quite a bit off base to me. Just wanted to point that out.
gcapel said:I would say there are mid high frequency's that are out of control high. Mabe overmastered? The mix sounds pretty even. I can pick out everything very well.
Those double kicks are fearless man. I got a little scared. I noticed some eriry hauted back up vocals.
xstatic said:My bad then. Somehow I got to it after following your links. If I were you, I might be a little careful with taking too much advice from that person.
Dude sorry, I had my eq on while listening. i complety take the mid freq comment back. I think it sounds fine man. Sounds very even all the way around. After mastering it would be golden.Bloodsoaked said:I have the mids on the overall mix a bit low as well. I am still very new to this and I am not sure how to tell if the mids are "out of control" as you said. I do know the overall mids have been lowered in the mix. The song is not mastered either. I mixed and have a limiter on the overall mix to keep it from clipping and it seems to even out all the tracks/instuments. Not sure if that is a good or bad thing to do.
Glad you like the back up vocals, that is my favorite thing. There is allot of fun to be had with death metal.
Peter
