Latency between signal and recording...help
  • Thread starter Thread starter Octava219
O
Octava219
I posted here before and someone helped me with this, but I went back and searched the forum and can't find the thread and can't remember how to fix it!! In the edit mode when I record it records a 1/4 scond later then the signal is entered. My sound card shows that it is picking up the signal in time but the waveform and level bar show a latency of 1/4 second or so. I appreciate the help!!
What soundcard are you using? Latency is entirely the fault of the soundcard and its drivers.
Still using a built-in soundcard?? Unfortunately, those are made with less than $1 worth of chips for beeps, boops and light gaming (not to mention cheapness for the manufacturer) and NOT quality music production. Even the cheapest $50 usb asio card will be a huge improvement.
#1 Rule of Recording: You MUST replace the built-in soundcard.
Here's a good guide and user-tested suggestions that work: The Best Audio Interfaces for your Home Studio by TweakHeadz Lab
(you'll want to bookmark and read through all of Tweak's Guide while you're there...)
Another good article: Choosing an audio interface - Choosing An Audio Interface
No..it's an M-Audio Delta 44. I had this problem before with the same setup and someone here told me how to fix it..
