ssscientist said:
I have a Compaq Laptop and the 4 pin Firewire port might as well not even be there. It's so fragile and in such a poor place on the housing of the computer that I'm sure any 6-to-4 adapter or cable would break right off in the tiny little port at the slightest invitation.
Don't get me started on laptop manufacturers using 4-pin FireWire ports. The 4-pin spec shouldn't even exist, IMHO, much less on computers. At best, it's okay for cameras and camcorders that have minimal case space. For computers, it's a crude hack, and if you have a choice, you should always favor a computer that doesn't use one.
IMHO, if a manufacturer cuts corners in the power budget and can't handle a powered FireWire port, you have to ask yourself what other corners they cut. I guess I could maybe accept it in some subcompact laptop, but even then, it's pushing the bounds of acceptability, IMHO.
BTW, you could always use a 6-4 cable. Then, there's no adapter to break off. Or you can use the reverse adapter at the opposite end of the cable in the 6-pin jack where the connector is strong enough to actually support an adapter.
ssscientist said:
Laptops are made for USB interfaces because of their (relatively) slow hard drives and relatively limited RAM. They also break easily and get stolen regularly. If vmock decides he likes computer recording he will eventually make an investment in a real dedicated desktop computer and keep it for music only.
In all my life, I've never had a laptop stolen. Where do you leave your laptop?
Laptops are the place you
most want a FireWire interface. The CPU in most laptops is woefully underpowered. USB devices eat CPU power for breakfast (and even more so if they're hanging off a UHCI controller).
For very slow devices (keyboards, mice, MIDI), the transfer rate is slow, so you don't notice. For devices that push significant amounts of data (hard drives, audio interfaces), that extra throughput can make the difference between your computer being able to keep up and ending up with pops and crackles.
ssscientist said:
As far as a USB connection for anything that uses Midi goes, even you can't find fault with that. Midi is a 31.2kB serial language from the early eighties and can't POSSIBLY tax a USB bus --- even the old 1.0 spec --- anywhere near capacity.
True enough. USB MIDI works fine. I wouldn't call it audio, though.
