B
Bryn
Hi,
I am selling these immaculate VXT 6 powered studio monitors with all cables and boxed as new. They have been the business for me and are an absolute joy to use. I am selling them to upgrade my studio.
I am happy to post them in the UK via parcel force which is about £30
£500 + postage (if required)
If you're interested please get in touch
Specifications are:
Configuration: 2-Way
System type: Active Studio Monitor
Low-Frequency: 6" Woven Kevlar woofer
High-Frequency: 1" soft dome tweeter
Frequency Response: 49Hz - 22kHz (+/- 3dB)
Max Peak SPL: 111 dB
Amplifier Class: Class A-B
Power Output: 90W
High Frequency: 30W
Low Frequency: 60W
Input Impedance (Ohms): 10 K Ohm balanced
HF Level Adjust: +1dB shelf / Flat / -1dB shelf
LF Level Adjust: whole, half, quarter
System Volume: (-30dB - +6dB)
Auto Mute: (on / off)
Indicators: Power, Clip, Limit
Indicator Control: Clip Indicator (On / Off / Limit)
Input Connectors: Balanced 1/4"/XLR Combo
Ground Lift: On / Off
AC Power Input: Selectable 110V-120V / 220V-240V (50Hz - 60Hz) or 100V (50Hz - 60 Hz)
Enclosure Construction: Structural Foam
Finish: Black Textured Paint
Port Configuration: Front firing slot port
Grille: Optional
Mounting: Bottom
Compatable OmniMount: 30.0 WBX
Dimensions (H x W x D): 14.36" (365mm) x 10.35" (263mm) x 9.66" (245mm)
Weight: 27 Lbs. (11.6 Kg.)
Specifications are:
Power Output: 90W
High Frequency: 30W
Low Frequency: 60W
Grille: Optional
Mounting: Bottom
