sk8a123
Whats the difference between the krk rockit 5, and the krk rockit 6. other than the size. I'm a newb and i've read up on it but its just not helping D:
oh wow. So it has nothing to do with frequency response or anything?
http://www.krksys.com/product_rokit.php said:Drivers: Woofer: 5" Glass Aramid Composite Woofer
Tweeter: 1" Neodymium Soft Dome Tweeter with Ferro Fluid
Input: XLR (3-pin), RCA & 1/4" TRS - 10k Ohm, Balanced / Unbalanced
Amplification: HF: 15 Watts/LF: 30 Watts
Freq Response: 53Hz - 20kHz (+/- 2 db)
Video Shielding: Yes
DimensionsH x W x D) 10 7/8" x 7 1/4" x 8 7/8"
27.6cm x 18.5cm x 22.5cm
Weight: 13.8 lbs (6.3 Kg)
http://www.krksys.com/product_rokit.php said:Drivers: Woofer: 6" Glass Aramid Composite Woofer
Amplification: HF: 18 Watts/LF: 50 Watts
Freq Response: 49Hz - 20kHz (+/- 1.5 db)
DimensionsH x W x D) 12 11/16" x 8 7/8" x 10 1/2"
32.1cm x 22.5cm x 26.6cm
Weight: 19.6 lbs (8.9 Kg)
http://www.krksys.com/product_rokit.php said:Drivers: Woofer: 8" Glass Aramid Composite Woofer
Amplification: HF: 20 Watts/LF: 70 Watts
Freq Response: 45Hz - 20kHz (+/- 1.5 db)
DimensionsH x W x D) 15" x 10 7/16" x 12"
38.1cm x 26.5cm x 30.4cm
Weight: 26.1 lbs (11.8 Kg)
well ......... the 5's are gonna be better than a lot of people use for moinitoring so you're not gonna go wrong with those.wow. So i guess i'll just save up and get the 5's. Seems like the 8 has somewhat of a difference, but eh
I'm gonna say yes but I'm interested in seeing what the real metalheads have to say.ahhh got it. Well my main objective is to be mixing metal. so i'll probably need the extra bass?
