Korg volca sample - firestudio project
  • Thread starter Thread starter davecg321
D
davecg321
I've got my korg volca hooked up from the mini headphone jack to two line inputs on my interface (ts leads) as I was told this is the best way to connect this unit. Trs leads caused phase cancellation and I wasn't getting any signal!
However, I still have to crank the preamps on the interface to about 10 o'clock to get a healthy signal.
Is this normal practice?
Thanks
D
I only have the FM, and I find it works well. I'm on the boxed battery set still : ) Output always seemed a little low, though. So, output on my FM might be 2 o'clock to mix with the other synths - more to move up front
Well, 10 is here \. Not 9 or 12, and 12 is half-way. My level isn't line level on my FM. It is amplified and the output is set with the Headphones/Volume knob. It's designed for low ohm fones, but the output is suitable for not harming interface line inputs.
The link didn't work, but the 3.5 mini plug should be stereo TRS and the other leads are TS
