KORG TRINITY PLUS 61-key + flight case (UK only)
  • Thread starter Thread starter glamslam
G
glamslam
KORG TRINITY PLUS 61-key Music Workstation *** comes with custom fur lined flight case & quick lock stand***
It breaks my heart to have to part with this trusty synth but needs must. This classic synth has been in my sole possession since 1996 and, all in all, it is in great condition and good working order. There are a couple of scuffs to the paintwork on the base but they’re really minor. There are only two problems which can be easily fixed by someone who has the know-how. 1) The headphone jack needs to be replaced as headphones don’t fit snugly in the socket. For the past couple of years I’ve been using it as MIDI keyboard and occasionally routing the sounds from the output and into my soundcard. This has been fine as a temporary workaround. 2) The GLOBAL & BANK buttons, which control settings needs to be fixed. Pressing these buttons won’t bring up the desired screens. I wouldn’t recommend purchasing this workstation unless you really know your hardware and can fix these small issues! Everything else seems to be working just fine. Collection only. I am based in London.
Specs: Sound Generation Method: ACCESS (Advanced Control Synthesis System), MOSS (Multi Oscillator Synthesis Synthesis System - Solo Synth. Sound Source: ACCESS = 32 voices, 32 oscillators (single mode); 16 voices, 32 oscillators (double mode), MOSS = 1 voice, Multi oscillator. Sound Source: ACCESS = 32 voices, 32 oscillators (single mode); 16 voices, 32 oscillators (double mode). Keyboard: TRINITY Plus = 61 notes with velocity and aftertouch sensitivity. Waveform Memory: 24 Mbytes PCM ROM. Effects: Stereo digital multi-effect system - 2 master effects and 8 insert effects simultaneously. 14 effects algorithms for master effect and 100 effects algorithms for insert effect. Program/Combination: 256 programs /256 combinations. Sequencer Section: 20 songs, 100 patterns, 1/192 resolutions, 80,000 notes, 16 tracks, 16 timbres, reads and writes Standard MIDI File. Expansion options: 1) Digital I/F option (DI-TRI); ADAT compatible optical outputs 2) Hard disk recorder option (with SCSI port): 3)tracks, 16-bit resolution, 48kHz sampling frequency, synchronizes with the built-in MIDI sequencer 4) SCSI option (SCSI-TRI); 4) Playback Sampler I Flash ROM option (PBS-TRI); 8 Mbyte Flash ROM board and sample playback system disk set. Controllers: Joystick, Ribbon controller, 2 x Assignable switches. Control Inputs: Damper pedal (SUSTAIN), Assignable (SWITCH,PEDAL). Outputs: ANALOG - 1/L/MONO, 2/R, 3, 4, Headphones. * An ADAT compatible digital output can be added by installing the DI option (DI-TRI). * An S/P DIF output can be added by installing the Hard Disk Recorder option (HDR-TRI). Inputs: None. * A digital Word clock in can be added by installing the DI option (DI-TRI). * An S/P DIF and two analog inputs can be added by installing the Hard Disk Recorder option (HDR-TRI). Floppy Disk Drive: 3.5 inch 2DD/2HD. MIDI: IN, OUT, THRU. Display: TouchView Graphical User Interface, 320 x 240 dots. Power Supply: AC, Local voltage. Power Consumption: 22 Watts. Dimensions:TRINITY = 1,090.1 (W) x 348.3(D) x 125.9 (H)mm Weight: TRINITY = 14.25kg
