KARMA engine
The KARMA function is truly great and inspirational. If you like to put up a simple drum track and start plaing and inventing, you will love the KARMA. However, if that is not your thing the KARMA may not be for you. Furthermore, the TRITON has more output options. Therefore, if you intend on making sequences on the instrument that you wish to bring to a studio and record, you will be better off with the TRITON. Also, as said above, the TRITON has sampling whereas the KARMA does not. This may not be a problem if you have either a seperate hardware or software sampler. Frankly, the way software samplers are going, I would seriously consider the KARMA for its functions since you cannot get that out of any software whereas you can get all the sampling you want out of software. The KARMA will add something you do not or cannot otherwise obtain. The additional features on the TRITON such as sampling can be gotten elsewhere if needed. The fact is, ultimately, the are the same instrument with the same sound engine, samples and sounds.
