Well, don't be afraid of the Korg; it's a blistering machine. Although I have design issues with the Roland approach, there's no question that the 1824 is one hell of a box as well.
But you might be under a misconception about the AKAI. From what I've seen, the AKAI unit has the
best support of anything on the market, including BBS access to the software developers at AKAI. (Who else gives us that?!) The final software build is fully developed and essentially trouble free, and the user interface is so intuitive that people typically are recording before they crack the manual.
The other thing about the option of doing 96 mHz recording (other than that no other machine in the class even offers it) is that you are at DVD audio quality
at every link in the signal chain until you actually get to the CD burn. That means you have vastly superior A/D converters for a better signal at the outset, the effects path is uncompromised, and mixdown is at a higher resolution than either of the other units.
When you do the burn to a CD (which is limited to 16 bit and 44.1 mHz rate) the AKAI allows full dithering in its bit conversion protocol, which means that you don't run into a rough conversion; you actually do get the benefit of the higher quality signal path and you can hear it in the result when you do get to 16 bit.
Again, either of these machines will do a beautiful job, and they took a bigger slice of a very competitive market than the AKAI did (probably because of the onboard burner capability) so the DPS16 went out of production and AKAI focused on higher end machines. My point is that the AKAI is still available and is very nearly in a class by itself. YMMV!
