K
kennyboy37
The RS16x16 is a 16x16 matrix switcher with composite video (BNC) and unbalanced stereo audio (part of Knox Video RS series composite routing switchers).
The RS series switchers accept up to sixteen composite, Y/C, or HD component video sources, sixteen balanced or unbalanced stereo audio sources, and connect any one of the input sources to one or more of up to sixteen outputs. Control of the switchers is accomplished via RS232 or the intuitive front panel control. The switchers are housed in an ultra-thin chassis, greatly reducing the depth needed and thus easing cable management challenges.
The RS Series are high performance audio/video routing switchers in a thin profile rack mount chassis. They accept and route almost any 1 volt Composite, Y/C, or Component video input signals. The RS Series accepts and routes mono or stereo unbalanced audio up to 2 volts p-p or balanced stereo audio from 0 to +18 dbm. Video and audio inputs can be routed independently; they need not have the same destinations. Easy manual operation by front panel push buttons, or simple RS232 commands from a terminal or third party controller. Knox control and scheduling software is also available. Internal timer allows timed sequence of patterns for surveillance applications.
• Up to 16 Inputs and Outputs
• Breakaway Stereo Audio
• Battery Backup
• DC to 200 MHZ
• Manual and RS232 Control
• Vertical Interval Switching
Written on every Knox switcher is detailed operation instructions enabling quick set-up for even the novice user.
Condition is excellent. When powering up you see the RS16. Routing patterns are easily changed and saved to memory. Included is a compatible power supply used for testing
I use an RS8X8 in my internet Radio Station.They are rugged and dependable.Comes with power supply. This switcher costs $3,500.00 new. Asking $395.00 Plus $18.00 shipping to the lower 48.At this price,it won't last long.It's going on EBay today.So let me know if your interested.If you want pictures,e-mail me at kennyboy37@hotmail.com
• Battery Backup
• DC to 200 MHZ
