E
earworm
ok,
finally bought small condenser overheads,
replaced my sm57's with oktava 012s
(from budget to better)
first i never cared about the position, as long as i had some crashes left and right, then i noticed extreme phasing problems,
then i started to work on my sound.
some guy told me that the "left" mic (when u're sitting behind the drumkit, im the drummer myself) should stand above the snare,
ok, did that,
then i put the right mic above the floortom,
it all worked, but i'm so uncertain about it,
at first i thought you'd just put the two mics straight above the
left crash and right ride, but this seemed to give phase problems,
and i guess i always put my mics too high,
don't have a good sounding room,
so what do you suggest,
put the mics about 6 inches above the crash? (wow thats close i think !!)
or u put them above the snare?
i especially wanna pick up cymbal sounds, all the rest is miked so there's enough volume
and my left crash sounds louder, more agressive and there's more hihat,
so the right mic should be a bit Lower (closer to the drums) so i get a more balanced stereo image?
can it harm my oktava mk012's with 10db pad screwed on if i put them about 6 inch above crash and ride?
i have no idea how much SPL these things produce,
and i think...the mics can handle about .... 130 if i can believe the unreadable russion specs
gonna record my first "seriuous underground band" this saturday...
he's bringing two crashes and a ride, its already set up , tomorrow i take an entire day for soundcheck,
so whatever you guys post, i'll try it out...
i can't mike from behind the drummer, cause the drums are a bit in the corner of the room, sorry, no other option, its a bedroom
since i got all toms and blabla miked up i assume i can put the mics pretty "low" and don't need a super overall sound, but a little more cymbals?
thanks in advance,
Earworm
ok, did that,
thanks in advance,
Earworm
