DrumRookie
"That" kid.
So as of yet I've still not made any bass traps because I've been err... Preoccupied. (a.k.a. lazy)
Now it's time for me to get back in line
with my objective right now: Build bass traps.
But I got this idea before I went to bed last night, what if I made a hybrid acoustic treatment/soundproofing panel? Seems like the odd or good ideas always come to you at 2:00 A.M...
A few possibly important details:
1. I have relatively low ceilings in my small basement dwelling (86 inches from floor to ceiling).
2. The room is mostly square, and approximately 10' 6" W x 9' 2" L
3. My desk is in the front left corner of the room. Unfortunately, I acquired the desk prior to the day that I figured out I wanted to start making a studio (a long time ago).
4. It's a corner desk.
(From what I've heard and understood, this is a no no.)
5. I really like this desk.
6. I don't wanna get rid of the desk...
7. But I will if it's going to prevent me from getting the best recordings I can.
8. I have a drum kit in the same room that I plan to mix in.
9. The kit occupies about 50% of the general area in the room.
I need to soundproof my room, as well as acoustically treat it.
My idea was to combine these two things into 1, sort of like a soundproofing/acoustic treatment panel.
I would be using one of these materials below for the acoustic treatment (planning to buy around 2 cases of 6):
Rock wool: Amazon.com: Roxul Acoustical Fire Batts, Mineral Wool, 2-inch, Case of 6: Musical Instruments
Rigid "rockboard" rock wool: Amazon.com: Roxul Rockboard 60, Mineral Wool Board 2" - Case of 6: Musical Instruments
Rigid Fiberglass: Amazon.com: Owens Corning 703 24"x48"x1" Fiberglass Boards - Pack of 6: Musical Instruments
I would essentially take This stuff (let me know if this material would work for good soundproofing), glue it (or nail it) to the back of a short wooden frame, place 1 piece of rock wool over (or in) the frame, and cover it with a material such as burlap or bed sheets.
The final result I estimate would come to around 5 - 5.5 inches for the ceiling clouds, and maybe 3 inches for the wall panels. I plan to just use rock wool for the wall panels.
And for the corner traps I would fill just the wood frame with rock wool as well.
So basically my main focus for this hybrid idea is for the ceiling, since 96% of the noise complaints come from upstairs.
The setup I was thinking was below:
1. To make 4 large ceiling panels in the hybrid method I came up with (the 4 panels would then cover 90% of the ceiling).
2. Make four 4'x3' "hybrid" ceiling clouds
3. Make 4 3' H x 2' W corner traps
4. Use the leftovers to make a few wall traps.
I also would like to use them once/if I move to another place, so I plan to make them non-permanent, and easily portable.
So is this is terribly crappy fantasy, or a possibly solution to my acoustic treatment and soundproofing problem?
I'd like to hear any of your thoughts or opinions on this, I would really appreciate it!
Thanks,
-DR
**My plan for the room (off topic, just for reference of what I plan to add or fix once I get a finished room).
1. Replace current, crappy speakers with KRK Rokit monitors.
2. Replace current kit with Gretsch Renown's or Mapex Saturn's (undecided between the two)
3. If the corner desk will prevent me from getting good, accurate monitoring, I'll replace it as well.
4. Be able to record nice, clean drum tracks
5. Have a suitable set up and environment for reasonably accurate mixing (and possibly for practicing some mastering).
6. Add more lava lamps.**
Thanks,
-DR
