Kick drum mics - AKGD112 vs Audix D6
  • Thread starter Thread starter DrewPeterson7
DrewPeterson7
DrewPeterson7
Sage of the Order
Ok, disclaimer, I DID do a search of the forum before posting this. ;)
So, the sense I'm getting is that the majority of you guys prefer the AKG D112 to the Shure Beta52 on a kick drum. However, maybe 2007-ish, the responses started to change gradually from a "hands down D112" majority to a mix of "definitely the D112" and "well, yeah, but have you tried the D6? It's better than both."
What I'm looking for - I'm not a drummer, but I will be tracking one for the instrumental guitar album I'm working on. I can hit my drummer buddy up for specifics on his kit if it would help here, but in terms of the way it'll need to fit in with the mix, I play a seven string guitar and a five string bass, so there's generally a fair amount of low end going on in the mix. I tend to err a little bit on the side of capturing the initial "punch" of the beater against the skin, and generally clamp down a bit with a compressor and a bit of EQ to pull back some of the rumble (this is with DKFH samples, and not live drums) and leave more room for a mahogany-bodied bass guitar and a basswood seven string through a Recto, tuned generally no lower than B. I'm something of a Devin Townsend fanboi, but don't generally like a drum sound quite that clicky - Porcupine Tree might be a better example.
So, for hard rock/instrumental metal with the occasional ballad, tuned fairly low but not quite down to Meshuggah-like levels, given the above rough idea of what I like from a kick... Which one of these would I be happiest with, and is there anything else I should consider? Thanks!
EDIT - if audio helps, again, these are sampled drums (and this is actually a Tech-21 Trademark 30, not my Recto), but this is about as heavy as it'd have to get: click me!
EDIT #2 - I posted something similar over in the recording section of a guitar forum I help run, and a lot of the guys there are telling me, based on what I write, I'll be happier either with 1.) a used D112, or 2.) saving my cash for a mic I'll never use anyway (it's a running joke that I'll never actually finish this album) and just buying some really nice scotch. :p Thoughts?
EDIT #3 - and here's another clip, for the softer side of how I write, if it makes a difference... Mix isn't great on this, but I think it's mostly the acoustic guitar, I was experimenting with micing from farther back and a couple months down the road I just thing the acoustic is too dark for this.
Killer clip...
I have a D112 and a D6. For that type of Kick sound, I wouldn't even consider pulling the D112, it'd be the D6.
Why not just plan on using Samples?
Killer clip...
Thanks, and thanks for the advice!
Easy. I'm a shitty drum programmer, and I happen to have a friend who's a seriously good drummer who's itching to play on something a little more diverse than his current punk/hardcore gig. Seems a no-brainer. :D
Bump - another forum I'm active on is pushing me more towards the AKG. Thoughts?
You would be VERY happy with a D-6. I've replaced my D112 with one. D112 sounds ok on bass guitar cabs, but it's too finnicky on bass drums. I used a Beta 56.....I didn't like it all....sounds boxy to me. I record mostly rock bands, and heavy bands. Everyone has loved their bass drum sound <- D6
Updated with one way less metal clip, for a sense of the range I'll be working within.
If you have an open mind to it, there are some reccomended vocal mics that are great Bass drum mics...Im using a Beyerdynamic M88 and it is supposed to be the best bass drum mic...the SM7...MD421 are a few mics that are better than the AKG d112 or Beta52...and you can use them on other things too.
Yeah, but that puts you in a slightly different price range, Darrin. :p I understand the SM7 is supposed to be an excellent vocal mic on the right voice, and I would expect the other two to be as well, but as I write instrumental guitar music and am a piss-poor vocalist, the added versatility for a 50-100% increase in price isn't a huge selling point for me. I'll get occasional use out of a D112 or D6 on a kick drum, and every once and a while on a bass cab, or occasional use out of any of those three on a kick, every once in a while on a bass cab, and maybe once I'll try singing through it, listen to the playback, and remember why I don't sing. :p
try all 3 and add in an
SM7B, MD421, SM57, u47 FET,
The last kit I recorded I used a D112 inside the drum a D6 towards the outer head.
and I drumagog the majority of both
