KARAOKE audio into DP01 FX
  • Thread starter Thread starter Phil777
P
Phil777
Hi there,
My Kumyoung Karaoke Machine has RCA output sockets currently connected to Receiver amp.
Is it possible to connect these RCA audio outputs into Line Input on Tascam DP01 FX (jacks on front)?
Or can anyone advise the best method to record the Karaoke audio tracks onto the Tascam?
Thanks,
Phil.
that should work fine, you will just need some rca to 1/4" adapters, and then you can run a second rca cable from your master out on the tascam to the receiver and you will still be able to have everyone hearing it, you'll probably have a little bleed and just be careful the mic doesn't pick up too much of what the stereo is outputting or you'll end up with feedback. hope this helps.
Thanks DuddyGuy. I just checked with Dick Smith's here in Australia and they have the converters I will need so will try it out tomorrow.
I'm hoping to record the Karaoke track and then add a vocal to it afterwards.
The mic I am using for the vocal is Rode NT-1A and it picks up everything so will not be connecting to amp at this stage.
Will post the results when I have them.
Phil.
