Armistice
Son of Yoda
OK - so have finished first full mix on Reaper of an old tune... trying to work out how to "master it" to stereo...
I'm just after the mechanics, not what FX, dynamics etc. to apply.
I'm thinking I enable the stereo track so it appears in with all the other tracks, then, if I want to, say, compress the whole mix, I'd click the FX button on that track and apply whatever compression I wanted to... same with EQ... dial up the master volume so nothing clips...
Then I Render As a stereo track - either a WAV or MP3 depending upon intended use... and voila! Done!
Or am I missing something?
Also, I haven't downloaded the LAME encoder on this machine yet, so I appear to need to do that to create MP3s...no problemo doing that.... is that the best way to go?
I'm assuming if I render both a WAV and an MP3 direct from the Reaper mix, it's a better process than creating a WAV and then converting that WAV to MP3 using Audacity or any other conversion method.. and probably easier anyway.
Cheers..
Cheers..
