OK... doing this will allow me to easily link to connectors together on 2 opposite wlal plates so i can just plug into the wall from either side and out and not have to run cable all over the place. i think i am getting the idea here....to finalize...is this correct.???
for XLR- i will combine the braided uninsulated wire, and one insulated wire together, solder that to the "1" pin on my XLR connector, and then route that same wire to the "1" pin in the back of the other connector on the other wall plate. I take the next insulated wire, solder to "2" pin, and then route that to the "2" pin on the other connecter. Finally, I take the third insulated wire and solder to 3, and then route that to 3 on the other connecter???
For the 1/4 inch, I do the same thing with the uninsulated wire and an insulated wire, soder them together, and then solder the combined wire to the GR "ground" prong, and then ultimatly route that to the other GR prong on the other connecter. Then i take the next insulated wire, solder it to TI "tip", and then route that to the other connectors TI. finally take the last insulated wire, solder to RI "ring", route that to the other connectors RI and thats it?
is all i have make sure i correctly do is make sure the wires on each little pin...make sure they go to the exact corresponding pin on the other connector???
i sure hope this is how to do it, this is driving me up the wall....and also, is their proper cable i have to use to make sure i get good sound??
