J
Jason M Hancock
I'm trying to educate myself about near-field monitors and amps and I'd like to purchase something within the next month. I'm trying to mix and match monitors and amps to come up with a good price on new gear.
I understand that the ohm rating of the speakers must match or exceed the ohm rating of the amp. Problem is, the amps I'm looking at have two ratings (4 ohms and 8 ohms) and most of the monitors I'm considering are rated at 6 ohms. To make it even more confusing, some of the amps say they'll have one wattage at 4 ohms and a different wattage at 8 ohms. ?! I'm looking at 6!
Do these amps have some switch to choose 4 or 8 ohms? Or do they just automatically adjust to any ohm rating within the 4 to 8 range?
And what the hay is "nominal" when it refers to a monitor's ohm rating?
Please help. I've listed below the units I'm considering. Will I have to call the fire department the minute I plug these in or will any combo thereof work?
Monitors
Tannoy Proto J: 6 ohms (nom. impedance) 50w (100w program)
Hafler M5: 6 ohms nominal 200w
Yorkville YSM-1: 6 ohms nominal 70w program
Alesis Mark One Mk2: 4 ohms 120w program, 200w peak
Amps
Hafler TA1100: 50w per channel into 4 ohms
40 w per channel into 8 ohms
Alesis RA100: 100w per channel into 4 ohms
75 w per channel into 8 ohms
Alesis RA150: 75w per channel into 4 ohms
45w per channel into 8 ohms
Thanks!!!!
Monitors
Amps
Thanks!!!!
