just ordered this system
  • Thread starter Thread starter lucid
L
lucid
any thoughts or ideas? tips?
AMD Athlon XP 1800
Asus A7M266 mobo
512MB Samsung 2100 DDR RAM
Maxtor 20 gig (system drive)
Maxtor 80 gig (audio drive) (7200 rpm)
DVD-ROM
LG CD-RW
voodoo 3 2000
will be using M-Audio Delta 44
if i can get an IDE controller, i will add a zip drive and a backup hard drive.
running WinXP Pro
If you just ordered it, wouldn't it be a tad too late for tips now?;)
It looks like a killer syste though. I'd skip the ZIP drive though. I never found them useful, especially now when CDRW are around.
Like the man said, great system.
You might want to do a search about using XP on the drive you will be using as your studio.
I am assuming your gonna use the 80 gig as "the studio"
If so run your system as a dual boot and use Win 2000 on the studio's drive.
Forget the zip drive and spend the money elsewhere. CDRW beats it all round on a bang per buck basis.
Take a look at the "sub $1000" post in this section.
Alan.
(By the way, I to have XP pro and have chosen to sit on it until there is more info and people have spent some time using it in a DAW environment. Later when all the niggles are know and tweaks available I'll go for it, right now its just "too new")
The only thing i would have done different would have been to get two audio drives (2 x 40gb instead of 1 x 80gb) and RAID0 them so that one drive reads while the other writes.
ps.
i just got a 1.2ghz, 512mb ram, 48g HD laptop (Dell) running windows XP for christmas. I'm going to get the VxPocket so I can do mobile recording on it.
thanks for the comments... i already have the zip drive and i use it to transfer smaller files quite ofetn, so that is why i still use it. CD-RW will be used to backup larger projects and so on. the two 40 gig drive thing was a good idea. but i think all will go well, i won't be needing to record 20 tracks at a time while playing back another 50...
about xp... program i use (samplitude) works well with XP, and m-audio has drivers for XP. if it doesn't work then i will go win2k.
That Asus board is great, I've got one with the 760 chipset sitting here, but according to everything I'm reading, and I mean EVERYTHING, the KT266a chipset is killing everything out there right now. I'd consider swapping the boards out for one with a KT266a chipset, very seriously. Also, will the Asus board take advantage of the Athlon XP's added features? Might wanna double check that one... otherwise, it'll be a fat system, I just think maybe a diff mobo is in order considering you can save $30 going with something like the Epox 8kha+ mobo and possibly improve performance quite a bit. Just a thought.
after reading all on via chipsets i decided not to go with it. i have also heard of delta/via clashes. so amd 761 best way for me i guess.
i will have to flash the asus board with the latest bios so that it can use the XP features.
