Hmmmmmmmm....dare I share my secrets?
Why not!!!
The first great laugh all of you will get is that I actually used a Alesis 3630 to compress the bass tracks!!! I know that I put this compressor down all the time, but I have always admitted that it does sound good for certain things. And on this CD, it is the ticket.
Ok. The bass tracks where recorded like this. I didn't track them, but know the producers techniques quite well as we work together often.
The bass was ran to a Country Man DI box. From there, the XLR out was run to a ART MP. The 1/4 out was then ran to a Hugh's and Kettner Bass/Bass head. The head was driving a Hartke
4x10 cabinet. That was mic'ed I believe using a C-1000 S ran to a ART MP.
So at mix, I have a DI and Mic track to play with.
I listened to the tracks and decided that the DI track had much better top end that the mic track. The mic track really did have a better low end too, so these tracks really covered all the bass's (all pun intended
). So, I eq'ed out everything below about 250Hz on the DI track and added some 1KHz and up on the channel. On the mic channel, I eq'ed out everything above about 6 or 7KHz. So basically I have a low end track and a high end track.
Next, I assigned them both to a sub group on the console and used the sub group insert point to insert the 3630. So, the compression was a Post Eq compression, meaning that the hotter frequencies would trigger the compressor as always, buy, now I have some control over that happening.
The compressor was set at a infinity to 1 ratio, attack was fast, and release was fast, both as fast as it will go. All's that I wanted to do was make sure that the attack of the notes where getting limited, but even then, not every note!!! Just the really loud ones.
That is about it. I just played with adjusting the low end and high end channel volumes, and played with the threshold on the compressor untill it sounded even and smooth.
Really though, the bass player is a killer player. He played on the Heavy Brothers CD, so I have had some history with his bass tracks. He is a very dedicated player, and really pays attention to his tone and articulation. That really makes a big difference in how his tracks sound.
Ed
