It's been a while .. so ..loop jams Digitech drum and bass.
  • Thread starter Thread starter nzausrec
nzausrec
nzausrec
Member
it's been a while ... would like to post some jams. I make my backing as I go. Then play over it. A Les Paul and ..
my chain is chorus (always on) - Opti comp (on) - centaur clone - GS1 Clone - SS3 clone - Digitech Bass and Drum looper with out to amp for the guitar at that point and an out to an EQ for the drum and bass cuts, then Vox amp with Mullards and JJ valves - then cndenssor (Blue brand) mic thru Scarlett and into Reaper with gain, reverb. I busk with this setup except the Vox is replaced by a battery amp and no post processing
I think for this style I would pull back the gain and go a bit cleaner on the melodic guitar part, it's got that "digital" sounding squared off top end to my ears which in an exposed part can be a bit much. Second thing I am noticing is that there does not seem to be a consistent room sound for everything, so you might want to work on a reverb send balance that can put everything more in the same "space" .
Codmate
Replies
6
Views
2K
Codmate
Codmate
