Is there a way to tell what your track's peak is?
  • Thread starter Thread starter TripleM
T
TripleM
I use HS 2002 (still). I looked around last night but couldn't find an answer to this...
Is there a way to determine a track's peak (e.g., -3db, -1db) somewhere in HS? If not, is there a plugin or freeware somewhere that will reliably do it?
Thanks.
in track view, you can see the .wav's peaks and you can compare that to the scale on the y-axis. I guess that's not super accurate but if you maximize the track to fit the whole window, the scale become pretty large so you can get a good idea. Just be sure to choose the appropriate scale.
that may also be tough if there are a lot of peaks... hmm that is interesting. there must be a way though.
Hmm... in Sonar, the VU meters in both track view and mixer view keep a running tab of values of the hottest peaks, but I'm gonna guess that HS2002 is more akin to my copy of Pro Tracks (also Cakewalk).
I took a quick look around the program and I didn't see a way to figure out how loud the loudest peak was (though I didn't dig very deep at all, I'll look again when I have more time). The best I could come up with was to go into console view, and under the playback meter options, select "Lock Peaks," which gives you a visual on how hot your loudest peak is. Again, it's not super-accurate, but it will give you a rough estimate, and with this method you can be sure you're estimating the highest peak.
Then again, I'm talking out of my ass if Pro Tracks is nothing like HS :D
Hope that helps.
That would be a nice feature to have! I always just set my meters to peak hold and then playback the whole song. :rolleyes:
Thanks everyone for the replies.
I noticed the "lock peaks" option on the meters. And I suppose you could drag the left half of the tracks pane way over to the right so it's really wide and add some granularity.
I didn't think of the y-axis thing. I'm guessing it would be about as accurate as the "lock peaks" method.
I was just wondering if there was something "precise." You know, like something that will just spit out a number - "-3.2db on the left, -3.3db on the right." Oh well.
