M
mykie_a
Like the title says...are they the equivalent cable? I can't quite remember. Thanks in advance.
Yes and no. I've done it before and it does work, but an AES/EBU cable is 110 ohm cable with XLR connectors. So, no they aren't the same, yes a mic cable will work. An AES cable will also work as a mic cable or patch cable.
All the Beldon cable I look up is 40 ohms.
Canare is 88 ohms.
There has to be a reason why you go to their sites and they have a separate section for '110 ohm AES/EBU' cable.
I've always wondered how you get 2 different channels in and out of those?
No I mean, the analog in and out of those AES units, they have the 25 pin connections on one end and the other end they have 8 XLR which carry 16 channels, or 4 that carry 8
well, there is an analog in and out on the back of units like rosetta 800 and lynx aurora in the form of a 25 pin connection. how do you connect your preamp outputs to those
Ah, so it's in the patchbay!
It's very important to not confuse the physical connector with the type of signal it's carrying.
