Re: one more question
Wireneck said:
SHould the hour counter on my adat ever reset? For some reason i think alesis may have reset it, when they worked on it. Im not at home right now but i think its reading something like
5 12. Is that only 5 hours? Maybe im just reading it wrong.
Yeah, what Cuzzin' Brucie said! Similar to trying to set back the odometer on an automobile!
Yo Cuz' Bruce, prior to buying the HD, I normally had my beloved ADAT's serviced at an authorized Alesis service center located in NY. When Alesis fell into fiscal failure, my friend who was employed there, was laid off and re-located to a southern state.
I purchased one of them Maxell/ADAT recommended head cleaners,popped it in my XT and waited for the head-cleaner to perform it's job! Upon completion, inserted a tape and what did you know, hi-end loss accompanied by signal distortion with the interpolation indicator flashin' every minute or so! I inserted head-cleaner again then popped in another tape with same negative results! A 3rd time insertion of head-cleaner,yet rather than risk destroying my tapes, I turned off XT in frustration and waited several days before using unit. Few days later,pristine sound with
no interpol indicater appearing when recorded tape was played.
Now the Maxell cleaner is only good for 20 head-cleaning jobs which I used only 3, I figured I was good to go, however i learned that after 20-30 so hours of ADAT use, the inter pol light would flash every now and then followed by tape/signal degradation. After calling my friend for advice,he informed that even though head-cleaner was designed for ADAT's, the band-cleaner portion of the Maxell causes slight abrasions on ADAT's heads and that the SOLE purpose of these head-cleaners were to provide a "quick-fix" for temporary head-cleaning,but to avoid
at all cost's unless one doesn't have the access to pro service.
ADAT's are intricate and tempermental pieces of equipment,requiring the utmost of care. I prev'ly tried using a short-cut and realized that more harm than good came out of my decision to use a head cleaner.
Though, I now use the HD, just wanted to thankyou for ADAT-care advice U have provided in the past about proper maintenance of these recorders !
