F
foggie
Have a general question about possibly removing the sheet rock from my ceiling and putting insulation in the cavities, then covering with a fabric etc..Awhile back I read Ethan's site on a room he did this on but had a few questions none the less.
1. Currently the room sounds really good but could be tightened up a bit > improving on what's already there, that's the goal. This space is for playing/recording and I'm not looking for a "pro mixing" formula. The floor is concrete but has a really thin piece of carpet. Thought of removing that and just having a remnant under the drums (if I do insulate the ceiling). I also thought about a riser as well but the ceiling is low as it is - undecided. Obviously the overheads don't have any room as they are right up against the ceiling (reflective, which isn't good). Building a cloud right over the kit is an option, but again ceiling height comes into the equation again.
2. My room is small (13x12), but as you can see I have (at least I think) the right amount of traps (4" corners, 2" everywhere else). The room and layout is exactly as the rendering. Ceilings are 7'.5"
Questions:
- It would appear a relatively inexpensive process to do this assuming I would be using standard pink insulation? Although the fabric could be $$, but was thinking Muslin.
- If the above is true are there any specifics for this (faced/un-faced, a certain kind) or is it just a matter of getting your garden variety insulation and stuffing it into the cavities and covering with fabric etc..
- By doing this would it possibly make the room worse or too dead? Or generally speaking are there and disadvantages to doing this. Thoughts?
Thanks!
Questions:
Thanks!
