sblair
I have a delta 66 and an audigy - Id like to use the delta in and the audigy out. this makes sense but in SX which is very unlike VST the have concept of configuring bus assignments per in and out then you can assign input/outs that are availble and I notice it is only seeing 2 of the delta inputs or at least I only have to drag drop options. Im very new to SX is there a concept where I can ensure the asio support for all th einputs are configurable even if that be a new bus and 2nd question would be how do in the mani mixer assign X channel to x input.. Ill be digging thru the pdf guides further as my dream of having a fairly quick go at it is coming to a hault since both the applications are very far apart. I figured id throw this out there in the meantime.
