input option
  • Thread starter Thread starter Jimmy2002
J
Jimmy2002
hey, iv just installed cubase sx 2, im using a M Audio Delta 1010, when cubase loaded for the first time it compleated the asio test and compleated sucsesfully. but for the inputs for the audio tracks i can only select the left and right of the standard sound card that came with the computer. how do i change it so i can select the inputs of the delta 1010. do i have to change a setting somwere
many thanks jimmy2002
I cant remember what it says at the top of the window but you need to go to "device set-up" Then you can choose your delta.
Yeah, Cubase must still see your onboard soundcard as the primary and is using its drivers. Your manual should clearly show you how to select the proper driver for your Maudio card.
