Want something really inexpensive? You can’t go wrong with the Alesis Stereo Micro Limiter at under $50.00 used. I bought one of these new when they first came out and now have two. It definitely goes on my list of the most overlooked/underrated. I can always find a use for them even though I have plenty of options that outclass them.
Ok, it is technically a soft-knee comp/limiter, but it has very short release time. The Micro Limiter also has no design relationship to the notorious 3630 or the newer nano Compressor. These are really two different companies -- then-Alesis and now-Alesis.
Here are the specs:
FREQUENCY RESPONSE: 20Hz To 20kHz +/- 1 dB
DYNAMIC RANGE: Input 100dB, output dependent on Ratio
DISTORTION: <0.2% THD @ 1 kHz 0dB
SIGNAL LEVELS: -10 dB to +4 dB nominal
ATTACK TIME: Program dependent 150ms to 0.5ms
RELEASE TIME: min 10ms, max 500ms
RATIO: 1:1 to infinity
I know a lot of people just won’t take this little 1/3 space “semi-pro” box seriously enough to give it a go, and it may indeed not be within the ballpark of what you’re looking for.
~Tim
