MOTU said:
Pro Tools is certainly great, but I use DP3 and am a big fan. I'm not a pro studio, but I am aware of pro studios using DP. I've never worked with Cubase, but I've heard good things. Anyone know what are the pros/cons of Cubase when compared to PT or DP?
PT has essentially created its own league, as near as i can tell, given their proprietary hardware design. Its great if you have the cash, and don't mind being fairly locked in, imho.
As near as I can tell, DP is "open hardware" ProTools (like open source, but not as ..y'know. ..free). There really isn't anything I've seen done on ProTools that one can't do under DP. The biggest advantages (to me) are that you can run it with or without the associated hardware (for working while on the go), that you can upgrade your hardware manufacturer at any time (i.e. switching between a motu interface, and a firepod or a tascam, etc), and that now with the JackOSX server system, you can run any plugin type with any suite without needing crossover/conversion plugins.
PT and DP is just professional choice, to me. If I had the cash for the hardware, I'd probably have chosen PT back in the day, given its use among higher-end professionals. But I wouldn't have been satisifed with something like a Digi002, i know that. As it is, I went with DP and Cubase (and MOTU hardware), but I haven't regretted it.
As for Cubase, it's useful, and a great DAW suite in its own right, but DP (at least 4.5) to me is much cleaner and more intuitive to use. I find myself quite often frustrated at Cubase's UI (this is under XP, btw). It takes me far too many tries to find an input channel, or open the EQ or insert settings. DP took me 5 minutes to get acquainted with.
Given the choice between the three (with or without the hardware I have), I'd go with Digital Performer, hands down.
Course, there's also a new project in the works called Ardour that's being developed for Linux, but has been ported to OSX. Once they get the gui looking not-linux-widgets, it's going to be HOT. It's quite cool. A bit of a learning curve, but I think it'll carve a niche for itself down the road.
