In the same league?
  • Thread starter Thread starter whattaguy
W
whattaguy
I know I might sound redundant, but here it goes:
These are the brief specs of my computer
P4 1.8GHz
512 RDRAM
40 gig hardrive
I am looking into the Aardvark Direct Pro 24/96 and the M Audio Omni Studio Delta 66.
Taking out the money factor, which one is better?
You're reply is much appreciated,
An anxious newbie
they are both great cards and you wouldnt go wrong with either......
Delta had 2 preamps ...the DP has 4....very similar quality.....
the DP has those DSP effects but i think you can only use them when recording and not during mixing.....
the Omni has inserts.....DP has none.....
the Omni has 2 headphone outs, DPhas one.....
many feature differences, and if $$$ isnt an issue it will come down to which one has the feautures you need....
http://www.aardvark-pro.com/direct_pro_2496.html
http://www.midiman.net/products/m-audio/omnistud.php
PS....
as far as reputation, the quality of both have impecable reputations.....Delta seems to have a better driver support reputation.....
I have both sitting in my room...don't ask why. Gotta return one or the other. My OS is XP and the finalized driver for the DP isn't available. The DP seems a little more user friendly, but not for sure, yet.
Thanks again.
of course you're right. however, the DSP effects are usable...depending on what you are doing, this could be a big plus....and the DP GUI is pretty neat....
yet , if you don't want the DSP or the GUI, or need four mic preamps, go with the OMNI STUDIO..
i should mention that the DP does have a midi input, though no onboard synth....i have used the DP to play midi keyboards with Reason on a slower p3 with negligible latency....the OMNI has no midi....though a soundblaster easily suffices for midi....
i've got the DP and the OMNI and don't plan on getting rid of either.
