W
wyn
Here's my setup:
I've got 2 Behringer mixers (I know, but Behringer has never given me problems). A Xenyx 2442FX, and an x2442USB. The FX (secondary) is connected to the USB (primary) via Main outs (1/4") to a line in channel on the 2442USB.
The 2442USB's main outs (XLR) are connected to a Harbinger HP118S powered sub, which has to two Behringer B215D's connected to it via the High Pass outputs.
The 2442USB is connected to a Windows 7 64-bit PC via USB cable, and I record into Audacity. All drivers have been updated from the Behringer website, and input and output have been set to 'Benringer Audio'.
Still with me? Here's where it gets weird.
I mute all channels on both mixers except for a mic that's nearby. I tap the mic, and hear the taps coming through the sub and the B215d's. I can see the sound is reaching the mixer (and the main outs) at a normal level via the LED lights (the mic is solo'd on the mixer and routed to the main mix).
The sound is also going from the mixer to Audacity because the VU meter in Audacity matches the LED indicators on the mixer.
Here's my problem:
Audacity is NOT recording the transients. The VU meter is moving with the signal accordingly, but again-- no transients (and thus no sound). On top of that, when I playback the recording, the output meter in Audacity is moving- So the system should hypothetically be working fine-- only Audacity is flat-lining.
Please help. I've been trying to fix this for 3 days now for hours each day. Any help will be EXTREMELY appreciated.
Here's my problem:
I would defiantly go with Geckos second thought on this one.
