Mr Clean
AKA Teddy Wong
Yesterday I read a rant that inspired me. *Thanks Greg
I can't exactly explain how because it would take too long, but it did.
Anyhow, last night I set myself a 2hr challenge to record a song, mic'ing up amps rather than the usual amp sims that I've almost always used in the past. I asked my Dad to pick the song, I requested something simple/easy and bluesy, so he picked Status Quo's In My Chair.
Part of the challenge to myself was I could only listen to the original twice and take notes, which I stuck to. Each take had to be played in full. No Comping! Which I also stuck to. And lastly, no excessive production. Get the sound, press record and do it.
The guitars used are a £79 (Made in China) Telecaster Copy and a Hofner Violin Bass. For the guitar, a Fender Champion 30 box thing and the bass was through my Ampeg BA210. I used the only dynamic mic I own which is a cheap AKG D680S.
I started at 10:30am and was finished by 12:22. I allowed myself 30 extra minutes for mixing although I can barely hear anything now, (that little Fender Amp is loud!) so the mix is probably crappy. It's pretty much a faders up mix anyway. A little EQ on the Kick and vocals and a reverb bus. Everything else is what went into the mic. The final wav was imported back into my DAW and I added some flavour with Vintage Warmer.
So have a laugh and see what you think. Maybe set yourself a challenge. It's great fun.
*EDIT* RE: The drums. In the haste of the recording, I completely forgot to change the velocity of the hits so every hit is maximum and the same for each drum.
I'll correct this when I revisit the mix.
