sausy1981
Hi people, I've been recording the last few years on and off but in the last 6 months I've started to do a lot more again. I've learned a lot from people in these forums and have decided to share what I've learned and what I know do different to what I used to do. The following list is not in any particular order with regards to recording and mixing start to finish. So here goes,
1. I used to record at the hottest signal possible without clipping, this is wrong, I now record with my peaks being -12db
2. When recording try and get as close as possible to the sound you want in the finished mix and eq when tracking with the mix in mind
3. Performance is eveything, keep trying until you get the performance your really happy with.
4. Use the meters in your daw when deciding on compression threshold and ratio
5. When eq'ing cutting is far better but if you have to boost do it lightly
6. Bass guitar generally needs a llot of compression, accoustic and clean electric need light compression and I never compress distorted guitars. When compressing vocals, when your happy with your threshold, ratio, attack and release settings decrease your threshold 1 or 2 db.
7. when using reverb do so lightly, create a bus and add a reverb, good starter settings would be somewhere between 1 and 2 second reverb with about 15 ms predelay and diffusion at 50%, then mess with the size.
8. When send to this reverb don't send all instruments to it, generally the drums sound better if just the snare goes to the verb.
9. Listening enviroment is so important, treat you room as best you can and gget the best monitors you can afford.
10. Start of mixing by doing as much eq as possible while mix is in mono, then start panning your instruments.
11. Song arrangement can really help with dynamics, for example instead of 3 guitar tracks played right through the song, maybe just have 2 for the verses and bring the 3rd in for the chorus, bringing instruments in and out of your mix will keep the song interesting.
12. Use a high pass filter on tracks that don't need low frequencies, a few examples would be, acoustic guitar @ 80hz, Vocals @ 100 hz, Electric guitars 150hz.
13. Use a reference track when mixing, import a professionally mixed and mastered song into your mix and compare it with your mix and listen to it on your monitors, it really gives you an insight and really helps when dealing with the low end of your mix.
14. If your on these forums, ask questions, there are lots of more experienced people here that will help.
15. Don't expect to get your mix right first time, most songs I sit down to mix can take up to a week with all the tweaking I do, and I go through countless cds playing my mix on different systems.
I hope these little things help some people who are starting off, I'm sure I'm forgetting about a few things but its hard to remember stuff when I'm not actually in the process of recording and mixing.
